| جديد الهندسة نت: |
أدوات الموضوع | انواع عرض الموضوع |
#1 | ||||||||||
نائب عريف
![]() VideoCharge supports the following formats: - AVI (Audio Video Interleave) allows you to work with any Video codec, installed into the system, and decode DivX, XVid and other type of files. - Mpeg (Moving Picture Experts Group) supports cording into Mpeg1 and decoding into Mpeg1, Mpeg2. Works with DVD and makes possible previewing and decoding of .vob files separately or as a group (applying data of .ifo files). - ASF, WMV, WMA (Advanced Streaming Format, Windows Media Video, Windows Media Audio) supports processing of Windows Media 7, 8, 9. - Wave (WAV) - allows you to work with audio data in RIFF format. It transforms audio files into any of the installed audio codecs, for example, Mp3. - Image files' formats: BMP, GIF, PNG, TIFF, JPEG. Except conversion mechanism, VideoCharge is used to perform other additional operations:- Merging Video, Audio or Image files sequences into single output file. - Splitting up Video or Audio file(s) into several equal files (splits), according to specified time range or size in bytes. - At the same time, if you use VideoCharge for Professional, you can preview all created splits and mark those of them which should be generated. - Definition of timelines and saving them as separate Video or Audio files. In addition VideoCharge includes the following functionalities: - Thumbnails: creating of screenshots for Video files and thumbnails in automatic mode. In this mode Image file(s) will be automatically created for each generated Video file, basing on the first or once defined frame. In custom selection mode applying Editor you can preview all frames of video file and select more appropriate of them to create screenshots. It is also possible to produce screenshots without conversion operation. - Watermark: VideoCharge allows you to add text or image to output Video or Image files. Watermarks can be used for protection of Video or Image files. Applying Watermark editor you can form any logotype quickly and easily and place it on output frame as you wish. - 25 Frame: VideoCharge allows you to create Video files with effect of 25th frame. It means that an image will be inserted into output file instead 25th (or other specified) frame. - Filters: VideoCharge represents about 10 filters, optimized for modern processors. Filters are used to improve quality of output video, solve problem of Interlace Video (just apply de-Interlace filter). VideoCharge also contains a convenient filters' editor, where you can preview results of filters application on Video or Image files. - Wizard: VideoCharge includes advanced Wizard, which can help persons to use the application without special background knowledge about Video treatment. Wizard includes 16 items, describing almost all scopes of the VideoCharge application. - DVD: VideoCharge supports processing of DVD and can be used as a usual DVD ripper, to make copies of DVD disks in Mpeg4 or other format. Besides VideoCharge allows you to select necessary partitions of DVD disks, sound stream, work with VOB (.vob) files or with groups of VOB files, described by corresponding IFO files. - Editor: VideoCharge represents a simple and easy in use editor to set time ranges, visually edit their boundaries, and select frames for Thumbnails. It is possible to preview all files, which will be generated, distribute files among folders, using drag-and-drop technology, set FTP parameters and so on. - FTP: VideoCharge has a FTP client, which allows you to upload generated files to one or several FTP servers! - Dynamic Path: VideoCharge represents technology of dynamic forming of output files names. - Command Line: VideoCharge For Professionals supports work with command-line, that makes flexible application settings. What's New in VideoCharge 3.7 : - New version of the product includes vast bug-fix for previous version, support of MP3 Audio output format, ability to add Header/Footer video* to the primary video file, DV decoding support. - Support of MP3 Audio (.mp3) output format – now .mp3 files can be easily created out of videos of all supported types. - Ability to add Header/Footer video* is the major feature of VideoCharge v.3.7. If having a great number of movies and wanting the very same small video logotype to be added at the beginning/end of all these movies, no .bat files are needed anymore. Add necessary movies, indicate Header/Footer video, click Run and that's all. - Support of DV decoding - now DV movies can be easily converted to any of the supported formats. Homepage - http://www.videocharge.com Download: 21.82 MB Pass: www.dl4all.com |
| إعلانات تجارية |
#2 | ||||||||||
نائب عريف
![]() For example a digital imaging software starts when the Safe containing your pictures is opened. Automatic Crash Protection (ACP) ensures that your data is encrypted, even in the event of an abnormal system shutdown or power failure.Steganos Safe is a security tool that allos you encrypt data. Unsafe passwords are automatically stopped: an in-built dictionary with almost half a million terms checks each password you enter. In this way, you can avoid using common - and therefore unsafe - passwords. The integrated Steganos Portable Safe offers the perfect protection for when you are on the move: sensitive data is simply saved in a data safe, then written to a CD, DVD, memory card etc. and can be decrypted on any PC without the need for additional software. Also includes the Steganos Shredder which destroys unwanted data quickly and definitively using the technology employed by the US military or the highly secure Gutmann method. With the help of the integrated Deep Cleaning Shredder, unwanted data is removed from the hard drive without a trace. FEATURES: - Fourfold Safe Size. Each safe now holds up to 256 GB! Create any number of secure drives. - Steganos PicPass. Use images as passwords! Memorize a sequence of images to open your safe. - Outlook Safe. Protect e-mails, calendar entries and Outlook tasks in the safe. This protects your Outlook data when you lose your PC. - iPod as a key storage or portable safe. Use your iPod to open your safe – or simply make it a portable safe. - Windows XP x64 Support. Safe now also supports the new 64-bit processor generation. - Hotkey Support. Open and close your safe conveniently using a key combination. - USB stick as key. Open your safe without a password – simply by USB stick, ActiveSync-enabled SmartPhone, PDA, memory card or digital camera. - Steganos Portable Safe. Simply take your encrypted data with you: On CD and DVD or even rewriteable on USB sticks. - 256 Bit AES. Real-time protection by the world's most advanced encryption algorithm - Steganos Shredder. Secure deletions with deep cleaning for the entire hard drive. - Only the best passwords. The in-built multilingual dictionary recognizes unsafe passwords – and warns you against these. Homepage - http://www.steganos.com Download: 18.64 MB Pass: www.dl4all.com |
#3 | ||||||||||
نائب عريف
![]() You can use GetRight to schedule your downloads for later; it can dial your modem at the set time, download the files you want, then hang up or even shut down your computer when done. GetRight has several features to get you faster downloads; it can use Mirror searching to find other places where a file may be downloaded--then switch between all the download sites transparently to ensure that you use the best one. And many more features-to many to list here! GetRight contains absolutely no extra advertising add-ons or advertising systems!GetRight will not (and never has) send us any personal information about you or your computer without your knowledge. GetRight® Pro Features : * Downloading Files * Scheduling * Dial/Hangup Modem * History of your Downloads * Uploading Files * History of your Uploads * File Synchronizing (Up & Down) * Browse FTP/Web Servers * More commands in GetRight Browser- Upload/Rename/Delete files, Upload/Rename/Create/Delete folders * Scripting Language - add uploads and downloads, dial your modem, etc. Allows scripting of all major features in GetRight Pro * "Client/Server" mode - have one computer on your network do all downloads * Global Speed Limit Controls for Total Speed of All Files * Speed Limit Controls for Individual Files * Use Scripts to Set the Speed Limit - create any sort of fancy Limit schedules you desire * Automatic MD5 file verification when download is done * Act as a Proxy Server - let programs that auto-update or download data (such as virus scanner updates) take advantage of GetRight's resuming, dialing, etc. * BitTorrent Downloads - download files using the BitTorrent protocol. * Web Access - control GetRight running on your computer from anywhere Major Changes in GetRight Pro 6 : - Added support for BitTorrent downloads. - Added Podcast Downloader to automate downloading files in a RSS feed. - Added ability to pick a playlist (from iTunes or Windows Media Player) so when a download is completed, it's automatically added to the playlist. This is part of the Podcast Downloader too, so it can automatically put files from a podcast source into the playlist you choose. - Totally redone graphics and logos. - Added support for FTPS downloads (both explicit ftps:// and implicit on port 990). - Added support for MD5 and SHA1 checksums to verify files. - Added a Language configuration item, to make it easy to use translations. - Added File Compare to the download status history mode, so can compare the size/date for a file you downloaded to the current file on the server. - Lots and lots of changes, fixes, and improvements. - Works on all versions of Windows: Vista, XP, 2000, NT, ME, 98, & 95. Changes in GetRight 6.2a: * Improved some appearance things for Vista...better toolbars, and a "Vista" color set for the graph. * Fixed some games button problems with XP in classic Windows look--could have been no icons. * Fixed filefront downloads that all were named X6 * Fix how small files could show the byte size in the percent spot. Homepage - http://www.getright.com Download: 5.27 Update: 3.5 MB Crack: Pass: www.dl4all.com |
#4 | ||||||||||
نائب عريف
![]() This encryption software enables users to securely store data and hide it from public view. It also allows them to send encrypted e-mails that require a password for the recipient to open it. Private data can also be hidden behind a picture or sound file. The software's Portable Safe enables users to encrypt data onto a CD or DVD, and then decrypt it on any other PC or laptop. Additionally, Steganos Security Suite 8 helps users manage their vast number of passwords and pin numbers and eliminate ones that might easily be found out. Finally, it deletes traces of PC and Internet usage and eliminates unwanted remnants of data from the hard drive. Features: - NEW! Safe Size 4 times bigger. Every Safe contains now up to 256 GB! Install as many secure hard drives you need * in real time with 256 Bit AES. - NEW! Steganos PicPass. Remember a sequence of images to open your Safe. - NEW! Outlook Safe. Protect E-Mails, Contacts, Calendars, and Tasks from Outlook in your Safe Access only possible with your password. - NEW! iPod® as key to your hard drive or as Portable Safe. Use your iPod® to open your Safe * or use it as Safe when you are en route. - NEW! Mobile Password Manager. Have your passwords always with you * of course encrypted: Thanks to the Password Manager on your Pocket PC. Including synchronization tool for your computer: This way, new and updated passwords are automatically transferred to your Pocket-PC. - NEW! E-Mail Encryption. Create self-decrypting e-mails: now you can send whole folders via e-mail. - NEW! Hotkey-Support. Open and close the Safe with practical shortcuts. - NEW! Private Favorites. Now you can save images as well in your password protected list of favorites. - AntiTheft Protection. In case your laptop gets stolen, Steagnos AntiTheft can provide you with information that may serve to recuperate your computer. - Internet Trace Destructor. Destroys surf- and work traces. Including Cookie Administration and XP protection. - Shredder. Destroys sensitive data irrevocably. Also includes the DeepSpace Shredder. - Hide and Seek: Steganography. Hide sensitive data in pictures and music. Homepage - http://www.steganos.com Download: 25.94 MB Pass: www.dl4all.com |
#5 | ||||||||||
نائب عريف
![]() Partition Manager helps you to: -Enhance computer performance, convert operating systems, defragment partitions, optimize your hard disk partitions cluster size. -Resize, move, hide, merge, restore and convert partitions without data loss. -Recover lost or deleted partitions; fix crashed operating system with bootable Recovery CD. -Copy partitions and whole hard drives adopting their size to target partition. Download: 22.05 MB Pass: www.dl4all.com |
#6 | ||||||||||
نائب عريف
![]() Highlights include: - Automatic update functionality - The AVG Resident Shield, which provides real-time protection as files are opened and programs are run - The AVG E-mail Scanner, which protects your e-mail - The AVG On-Demand Scanner, which allows the user to perform scheduled and manual tests - The AVG heueristic analysing monitor - Free Virus Database Updates for the lifetime of the product - AVG Virus Vault for safe handling of infected files - Great customer satisfaction! Homepage - http://www.grisoft.com Download: 25.69 MB Keygen: Pass: www.dl4all.com |
#7 | ||||||||||
نائب عريف
![]() Products Supported: Radeon® X1900 series Radeon® X1800 series Radeon® X1600 series Radeon® X1300 series Radeon® X850 series Radeon® X800 series Radeon® X700 series Radeon® X600 series Radeon® X550 series Radeon® X300 series Radeon® 9800 series Radeon® 9700 series Radeon® 9600 series Radeon® 9650 series Radeon® 9550 series Radeon® 9500 series Download ATI Catalyst 7.2 for Windows 2000/XP Display Driver: Download ATI Catalyst 7.2 for Windows 2000/XP With Control Center: كود:
http://ati.amd.com/support/drivers/xp/radeonx-xp.html كود:
http://ati.amd.com/support/drivers/vista32/common-vista32.html http://ati.amd.com/support/drivers/vista64/common-vista64.html |
#8 | ||||||||||
نائب عريف
![]() With Flash Player Pro you can: Download flash movies from the Internet Browse Macromedia flash movies with built-in swf player. View or play flash movies with built-in player. View or play movies in full screen model. Make flash screensaver with a few mouse-click. Make flash screensaver installer and distribute it with ease. Capture flash movie image and save it. Capture flash movie image and set wallpaper. Build your own favorite folder, and browse flash movies in it. Make conversion between SWF and EXE flash movies. Copy or move flash movies to another folder. Rename flash movies. Connect with .swf file extension Download: 1.82 MB Pass: www.dl4all.com |
#9 |
قائد متدرب
يسلموا يابطل ,, برامج جداً رائعة ومفيدة
مــع الــتــحــيــة....
__________________
ما كل ما يتمناه المرء يدركه *** تجري الرياح بما لاتشتهي السفن |
#10 | ||||||||||
نائب عريف
![]() Features: - Import SWFs as editable movies - Import FLV Flash Videos - 51 action script based text effects - 100 stylish text effects templates - 343 clip art items and buttons - 20 web interface templates - Transition, spin, rotate effects - 4 skill levels (wizards to cartooning) - 7 unique views of the animation - Easy to create mouse-over effects - Flash MX action scripting - Easy to use preloaders - User interface components - Bones for character animation KoolMoves is an affordable Flash authoring tool that is full featured and easy to use. It is ideal for creating a wide range of web content with high impact visuals, MP3 and WAV sound. The functionality services a broad set of web design needs: • high impact visuals with sound • animated text effects • general web sites • flash banners • multimedia slide shows • dazzling splash pages • flying logos • complex navigation systems • character animation • interactive games • and much more... Homepage - http://www.koolmoves.com/ Download: 3.06 MB Pass: www.dl4all.com |
| مواقع النشر (المفضلة) |
| الذين يشاهدون محتوى الموضوع الآن : 1 ( الأعضاء 0 والزوار 1) | |
| أدوات الموضوع | |
| انواع عرض الموضوع | |
المواضيع المتشابهه
| الموضوع | كاتب الموضوع | المنتدى | مشاركات | آخر مشاركة |
| اكثر من 987 برنامج كامل وجاهز الحق | GIGA | منتدى البرامج والكراك | 41 | 05-04-2010 01:38 PM |
| (مهم جدا) مشاكل وحلول وندوز .... كل مشكلة لها حل | tzrg | منتدى أنظمة التشغيل | 26 | 29-09-2009 02:51 AM |
| مئات البرامج الكاملة هنا | abo-janna | منتدى البرامج والكراك | 13 | 13-04-2009 02:37 PM |
| أكبر موسوعة مواقع تخص الأجهزة | MxWorld | القنوات الفضائية والشفرات | 63 | 08-01-2009 09:56 PM |
| مواقع... | mado_el7op | القنوات الفضائية والشفرات | 1 | 29-10-2006 08:36 PM |
